Here are 2 features to add to Network Atlas.
1. The ability to add a wireless thin AP to a map and display the status.
2. The ability to have an object in the MAP but not have it count in the status of the map.
Many of my maps have two uplinks maps in the map as an objects in the maps. And if any object is down then this down state will flow over to all the maps. So on my map I have to remove the assignment of the object status from all my uplinks map objects that are in the map and manually set the hyperlink. So it would be nice if I could see the status and have the hyperlink set automatically in the map and not have this object count for the map status.
