Hi All,
We are running NTA 4.2.1 and NPM 12.0.1 to gather flow data for customers connecting to our systems. The sales team sometimes use NTA to run reports to see the detail of data used by source IP address for a given time period. They do this by logging into the NTA summary screen, entering the customers IP address in the Top Right Hand corner and selecting Endpoint IP address. and then changing the time period, typically they will be selecting all of the previous month. These reports can run for hours (or until the browser times out). I'm seeing lots of long running query events in the orionweb.log (as seen below). We have a dedicated SQL 2016 server for the DB, a dedicated Flow DB Server and a dedicated NPM server which is running the web interface, puller etc. None of the servers seem to be under significant load. Is there something I can do to optimise these queries as it becoming unusable. I accept we may be going about this the wrong way. All they want to be able to do is put in a client IP address and get a report for a given time period that shows source and destination (inbound and outbound) to the customers IP address broken down by traffic type. Is there a better way to do this? Any help or advise much appreciated.
2016-12-15 15:37:42,617 [18] (2) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 85295.4193 ms: SELECT TotalBytes
FROM Orion.NetFlow.TransferredDataTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=0, Rx=False, Tx=True, TransferredDataType='Bytes', ReturnAsTransferred=False, TopKey='' ) RETURN XML RAW
2016-12-15 15:38:24,196 [17] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 131123.694 ms: SELECT DirectionID, DirectionName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress as TotalPacketsIngress FROM Orion.NetFlow.TransferredDataTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, Rx=True, Tx=True, TransferredDataType='Packets', ReturnAsTransferred=False, TopKey='') RETURN XML RAW
2016-12-15 15:38:24,274 [16] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 131142.531 ms: SELECT DirectionID, DirectionName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress FROM Orion.NetFlow.TransferredDataTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, Rx=True, Tx=True, TransferredDataType='Bytes', ReturnAsTransferred=False, TopKey='') RETURN XML RAW
2016-12-15 15:38:24,290 [18] (2) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 41670.0431 ms: SELECT TotalBytes
FROM Orion.NetFlow.TransferredDataTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=0, Rx=True, Tx=False, TransferredDataType='Bytes', ReturnAsTransferred=False, TopKey='' ) RETURN XML RAW
*** Assembly SolarWinds.Licensing.Framework, Version=3.0.0.477, Culture=neutral, PublicKeyToken=0bdb206719860e1f, .NET version v4.0.30319 ***
*** Assembly SolarWinds.Orion.Licensing, Version=1.0.0.752, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2016-12-15 15:38:24,820 [21] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 131679.2934 ms: SELECT AppID, ApplicationName, MapTo, ProtocolName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress, TotalPacketsIngress
FROM Orion.NetFlow.ApplicationsTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, Rx=True, Tx=True, TopKey='') RETURN XML RAW
2016-12-15 15:38:25,304 [11] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 132168.4828 ms: SELECT Protocol, ProtocolName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress, TotalPacketsIngress FROM Orion.NetFlow.ProtocolsTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, TopKey='') RETURN XML RAW
2016-12-15 15:38:25,335 [14] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 132192.665 ms: SELECT CountryCode, CountryName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress, TotalPacketsIngress FROM Orion.NetFlow.CountriesTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, Rx=True, Tx=False, TopKey='') RETURN XML RAW
2016-12-15 15:38:25,350 [15] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 132202.1329 ms: SELECT CountryCode, CountryName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress, TotalPacketsIngress FROM Orion.NetFlow.CountriesTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, Rx=False, Tx=True, TopKey='') RETURN XML RAW
*** Assembly App_Web_lyuf3uxp, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2016-12-15 15:38:27,394 [20] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 134245.7984 ms: SELECT TosID, TosName, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress, TotalPacketsIngress FROM Orion.NetFlow.TosTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, TopKey='') RETURN XML RAW
*** Assembly App_Web_inaccuratedatawarning.ascx.be89cd80.vcauplmm, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null, .NET version v4.0.30319 ***
2016-12-15 15:38:38,487 [12] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 145333.3406 ms: SELECT Caption, NodeID, InterfaceID, TotalBytes, TotalPackets FROM Orion.NetFlow.UniqueVisitorsTop(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', Limit=5, Rx='True', Tx='True', TopKey='') RETURN XML RAW
2016-12-15 15:39:05,165 [16] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 26680.3404 ms: SELECT Caption, StartTime, TotalBytes
FROM Orion.NetFlow.UniqueVisitorsDetail(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', TopKeys='Visitors', Absolute=False, Rx='True', Tx='True') RETURN XML RAW
2016-12-15 15:39:05,773 [25] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 41473.644 ms: SELECT DirectionID, StartTime, TotalBytes
FROM Orion.NetFlow.TransferredDataDetail(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', TopKeys='Transmitted,Received', Absolute=False, Rx=True, Tx=True, TransferredDataType='Packets', ReturnAsTransferred=False) RETURN XML RAW
2016-12-15 15:39:06,366 [23] (0) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 42057.8872 ms: SELECT DirectionID, StartTime, TotalBytes
FROM Orion.NetFlow.TransferredDataDetail(Filter='NSF:E:***.**.**.***;I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;FD:Ingress', TopKeys='Transmitted,Received', Absolute=False, Rx=True, Tx=True, TransferredDataType='Bytes', ReturnAsTransferred=False) RETURN XML RAW
2016-12-15 15:39:24,276 [19] (3) WARN SolarWinds.InformationService.Contract2.InfoServiceProxy - (null) Support! -- LONG RUNNING QUERY: 57537.3045 ms: SELECT ConversationID, IPSort1, IPAddress1, Hostname1, IPSort2, IPAddress2, Hostname2, NodeID, InterfaceID, TotalBytes, TotalPackets, TotalBytesIngress, TotalPacketsIngress
FROM Orion.NetFlow.ConversationsTop(Filter='NSF:I:1;TD:2016-12-01T00:00:00~2016-12-15T23:45:00,360,True,False;E:***.**.**.***;FD:Ingress', Limit=25, TopKey='') RETURN XML RAW
