I have an Adobe Connect server running on 10.10.46.70 that uses ports 80 and 1935 for it's traffic. I know that much.
I set up an IP group to monitor that IP address. When I run the report for a specific interface, the Web traffic on port 80 is showing up in "Top 5 Applications", but 1935 is not? Unmonitored traffic is showing up as 56%, web as 80% and then a couple of other random (greater than 1024) port numbers.
If I run the same type of query in another Netflow tool, same IP, same router interface and search for IN and OUT traffic for 10.10.46.70 - I see all of the traffic is port 80 and 1935.
Is Solarwinds using the random port chosen for the conversation as the application type?
I see 1935 is registered in the program as a Macromedia application, but it's not showing up in my graphs at all.
Thanks for any insight.
---John Holmes...
