The SAM team is in the investigatory phase of hardware heath monitoring of server blade chassis from HP, Dell, and IBM. But we need the communities help. There are countless different chassis configurations between these different vendors and models that we could never hope to build and test them all without your help.
We're currently seeking volunteers willing to perform SNMP MIB walks against their HP, Dell, and IBM blade chassis. These MIB walks will be used exclusively to test and ensure any hardware monitoring features developed will work properly with these chassis.
If you'd like to see Hardware Health Monitoring for your server blade chassis in a future release of SAM, then we strongly encourage your participation.
What we need: An SNMP MIB walk using the tool provided from your blade chassis. The tool is fairly simple and straightforward to use. Enter the IP address of the Server running the agent as well as the community string and click "scan".
Alternate method: If you'd prefer to use NET-SNMP instead of the tool provided above you can download and install NET-SNMP from http://net-snmp.sourceforge.net/
• Win32 binaries are available here: http://sourceforge.net/projects/net-snmp/files/net-snmp%20binaries/5.5-binaries/net-snmp-5.5.0-1.x86.exe/download
• Run this command from “installation directory/bin/”: snmpwalk -v 2c -c public -O netU 127.0.0.1 1 > output.txt
(change the IP address and community string accordingly, and don’t forget there is 1 after IP address. It means it will scan whole SNMP tree)
What Now: Both methods will generate a single file per blade chassis containing a complete MIB walk of the device. We recommend naming this file the make and model of the device that was scanned. For example "DELL_M1000.txt".
These files can then be posted here to this thread or emailed to me directly at the email address below.
The more people who participate, and the more blade chassis we receive MIB Walks for, the more likely we'll be able to incorporate this as a feature into a future release. We encourage everyone to participate and appreciate your willingness to help.
[Standard obligatory Legal Disclaimer Stuff]
This is not a commitment to a timeframe or delivery of any of the features discussed above. This post is intended solely as an opportunity for community members interested in participating to aid and assist SolarWinds in gathering research data.
