Hi All,
I implemented NPM and NTA on our client..
I'm having a problem in discovering the routers using NTA
Our client have 5 routers lets say R1, R2, R3, R4, R5
R2, R3, R4, R5 are all connected to R1 via MPLS.
I enabled ip flow-export source on R2 at Serial0/1/0.361
I enabled ip flow-export source on R3 at Serials0/1/0.160
I enabled ip flow-export source on R4 at Gigabitethernet0/0
I enabled ip flow-export source on R2 at Serial0/0/1
I also enabled SNMP on all of these router and I discovered them all on NPM
I set public as their credential in SNMP
But when I'm discovering them on NTA using manual discovery
I'm having an error when I type their credential on the "Read/Write Credential"
It seems that NTA doesn't accept the credential that I typed.
This scenario happened except for R4, but for the remaining routers (R2, R3, R5) the one one that I mentioned above are the scenarios that I encountered.
What could be the possible solution for this?
Please help..
