Hi All,
I am trying to update the credentials of an emergency username and password for all of my IOS devices. I have 2 problems currently:
1.) NCM logs into my test device and starts to execute the script. Once finished, NCM through the web console shows "Connection Refused".
2.) After I decrypt my Cisco passwords in the config, intermittently, 2-3 of the passwords that are changed, have characters replaced with multiple question marks. For example, if my password is "PopTart5!", the password is actually reading as "PopTar???" after I decrypt it. Sometimes It will only have 1 ? mark at the end instead, so it isnt quite consistent.
I am currently running NCM 7.4. Below is the template I have taken from online and modified to fit my needs. Any idea what is going on here?
.CHANGE_TEMPLATE_DESCRIPTION
Updates the passwords redentials on Cisco IOS and NX-OS devices.
.CHANGE_TEMPLATE_TAGS
Cisco, Nexus, NX-OS, Password,
.PLATFORM_DESCRIPTION
Cisco IOS, NEXUS
.PARAMETER_LABEL @ContextNode
NCM Node
.PARAMETER_DESCRIPTION @ContextNode
The node the template will operate on. All templates require this by default. The target node is selected during the first part of the wizard so it will not be available for selection when defining values of variables.
.PARAMETER_LABEL @EmergencyUsername
Local Emergency Username
.PARAMETER_DESCRIPTION @EmergencyUsername
Enter the Emergency Username for the device(s).
.PARAMETER_LABEL @EmergencyPassword
Local Emergency User Password
.PARAMETER_DESCRIPTION @EmergencyPassword
Enter the new Emergency User password for the device(s).
.PARAMETER_LABEL @EnablePassword
Enable Password
.PARAMETER_DESCRIPTION @EnablePassword
Enter the new enable password for the device(s).
.PARAMETER_LABEL @ConsolePassword
Console Password
.PARAMETER_DESCRIPTION @ConsolePassword
Enter the new Console password for the device(s).
.PARAMETER_LABEL @VTYPassword
VTY Password
.PARAMETER_DESCRIPTION @VTYPassword
Enter the new VTY password for the device(s).
script UpdateSNMPandPasswordCisco (
NCM.Nodes @ContextNode,
string @EmergencyUsername,
string @EmergencyPassword,
string @EnablePassword,
string @ConsolePassword,
string @VTYPassword
// Only select Cisco devices
foreach ( @node in @ContextNode )
if ( @node.SysDescr Contains 'NX-OS(tm) n' )
//ONLY SELECT NX-OS DEVICES
// Set or update NEXUS Emergency User and Password
CLI
configure terminal
username admin password 0 @EmergencyPassword role network-admin
if (@node.SysDescr contains 'ucs' )
// Do nothing if UCS device
if (@node.SysDescr contains 'IOS' )
// ONLY SELECT IOS DEVICES
// Enter configuration mode
CLI
configure terminal
// Set or update enable Password
CLI
enable secret 0 @EnablePassword
// Set or update Emergency User and Password
CLI
username @EmergencyUsername privilege 0 secret 0 @EmergencyPassword
// Set or update Console Password
CLI
line con 0
password 0 @ConsolePassword
// Set or update VTY Password
CLI
line VTY 0 4
password 0 @VTYPassword
exit
line VTY 5 15
exit
// Exit configuration mode and write config
CLI
exit
copy run start
startup-config
