Wanted to reach out to the community to see if anyone has taken the tools provided in Orion and developed any functional automation off of them? I understand that the compliance tool is there and can check the stored running configuration but the logic it has is limited and does not seem to lend itself toward easy automation and remediation of issues.
For example, we want to audit X variable in our configuration that is a standard in our organization. However between the various platforms in our network IOS, IOS-XE, NXOS and others the configuration is not going to appear the same in each "running-config". To match this example you would need to check the device type and software then match the proper config to that device once the variables are matched and execute remediation. I understand you can build groups to sort devices into and then run compliance reports against each group, however, this requires a ton of manual work to identify the unique charactierstics of each group to match with the compliance report being built. In many ways having to sort into groups to match the report being built truly defeats the goal of automating these task as so much manual work would have to be done for each possible combination.
If anyone has any insight or example of how they've done this in their own organization that they would like to share that would be great.
