Knowing the types of traffic that normally (baselines) traverses the network is a plus! This is definitely a cool tool if you don't have it, get it! You will see it's benefits.
Thanks for including the split-tunnel VPN option! To be fair, we weren't using this at all until everyone started working from home and using audio/video collaboration tools at significantly higher levels.
None of these options apply to us - we do not have a remote workforce.
None really apply either. I had just racked the server hardware for our Solarwinds solution when we were sent home. I hadn't set up remote access to the tin so can't install O/S or Orion. I would have had all the monitoring set up which would have been very useful in the event of a major situation but unfortunately the major situation happened first. Ho Hum.
