Hi all,
Does anyone know exactly what the msg
"You have not enabled NetFlow data export on <ip address> device. For more information, see "Enabling NetFlow and NetFlow Data Export (NDE) on Cisco Catalyst Switches" in the Support - Product Documentation area of www.solarwinds.com."
actually means?
I tried to enable netflow on a 6509 running catos using the same settings as a similar 6509 switch (which works fine) and I see this msg appear in NTA. The only different between the switches is that this 6509 doesnt have any MSFC cards in it (the working one does) - we dont do any routing on this new switch. Can I get netflow data out of this?
Current config:
#mls
set mls flow full
set mls bridged-flow-statistics enable 1,19,460,619
set mls nde version 5
set mls nde <IP address of Orion> 2055
set mls agingtime long-duration 128
set mls agingtime 32
set mls agingtime ipx 32
set mls nde enable
Anyone got any ideas? I have auto-add turned on - but NTA doesnt add the Netflow data - switch shows it's exporting flows fine.
Thanks for any help!
