We currently have three devices monitored per site -
router, switch and access point. So for each site we have Store
xxxx Router, Store xxxx Switch and Store xxxx Cloud AP where xxxx is the
restaurant number.
I have set up a daily report which lists the restaurante where
for example the AP is down but the router is up by using the SQL:
select substring(Nodes.Caption,7,4) as "Restaurant",Nodes.Ip_address as 'IP Address' from Nodes
where nodes.caption like '%AP%' and (nodes.region ='Restaurant')
and (nodes.status='2') and substring(Nodes.Caption,7,4) not in (select
substring(Nodes.Caption,7,4) as "Device" from Nodes
where nodes.caption like '%router%'
and (nodes.region ='Restaurant') and (nodes.status='2'))
order by 1
What I would like to do is the same thing for alerts as the
issue occurs, but can find no way of doing this alert suppresion dependent on
another node status.
The reason I need this is if the router is down the switch and
AP will therefore be down and I only want to generate one alert and not
three.
Can you assist with this.
