Hi All
1ST Post
After upgrading from W7 to W10, my dameware no longer saves the settings for Authentication Options (they are ticked though) in the Default Host Properties. It also no longer saves a list in the Saved Host List. Although it shows as everything is 'ticked', the settings dont carry through to the Remote Connect box.
64bit dameware
64bit W10 enterprise
