Anyone else have the problem of the endpoints not being sorted by % bandwidth utilization?
I didn't think Top XX Endpoints was sorted by %. At least mine doesn't appear to be.
Each resource is sorted by column TotalBytes, and in case that % reflects this, it should be the same.
But you mentioned bandwidth utilization, and there is no column utilization, so ..... do you mean some other endpoints resource or report?
thanks
No, I meant % of bytes. They all seem to be sorted properly now - it seems like it just takes a while (up to half an hour) after I add NetFlow sources until it is sorted correctly.
Hi Scott,
If you have some time, I'd like to get your opinion on some data display options.
Andy
