Having some problems on a fresh install of NCM v5.5 -- the software seems to install fine, but when the configuration wizard gets to the restarting services point it displays this error:
"An error occurred configuring a plugin: Object reference not set to an instance of an object..."
In the wizard log I have this:
2009-05-27 21:21:21,219 [1] INFO ConfigurationProgressScene - Restarting ASP.Net Application ...
2009-05-27 21:21:21,221 [1] INFO ConfigurationProgressScene - Restarting Website ...
2009-05-27 21:21:21,254 [1] INFO ConfigurationProgressScene - Updating website configuration file ...
2009-05-27 21:21:21,327 [1] INFO ConfigurationProgressScene - Website started successfully
2009-05-27 21:21:21,328 [1] INFO ConfigurationProgressScene - Restarting Services ...
2009-05-27 21:21:21,332 [5] DEBUG DatabaseHelper - SQL Server on "SUN-ORION" reports its ProductVersion as "10.0.1600.22".
2009-05-27 21:21:21,336 [5] DEBUG DatabaseHelper - SQL Server on "SUN-ORION" reports its InstanceName as "".
2009-05-27 21:21:21,336 [5] DEBUG ConfigurationProgressScene - addServiceDependencies - True
2009-05-27 21:21:21,336 [5] DEBUG ConfigurationProgressScene - version - Unknown
2009-05-27 21:21:21,336 [5] ERROR ConfigurationProgressScene - Exception while configuring plugins.
System.NullReferenceException: Object reference not set to an instance of an object.
at SolarWinds.ConfigurationWizard.Host.ConfigurationProgressScene.EnsureServicesAreStarted()
at SolarWinds.ConfigurationWizard.Host.ConfigurationProgressScene.DoConfigInThread()
I'm running Win2008, SQL 2008. Any ideas? I will say that if I just hit ok and click on finish, NCM seems to run ok. I havent' tried adding any nodes yet though.
--Brandon
