I seem to be having a weird problem. I noticed that when I go to add in a new physical node I would not see the network adapter on the page where you select the resources you want to monitor. In the past there were no issues with that so not sure when this issue popped up since we don't add many physical nodes in that often these days. We recently upgraded to SAM 6.2.1, NCM 7.4, and NPM 11.5.2. I also noticed that on the physical nodes that are already monitored I do see the network adapter when I expand out the node but if I do a List Resources on it the adapter doesn't show under there. Most of our physical servers are HP Proliant servers. What I found to fix the problem was uninstalling the HP Insight Management Agents from the server then the network adapter would show up in the resources screen. Problem with that is I then lose my hardware monitoring capabilities. Anyone have an idea as to why I can't see our network adapter with the Insight Management Agents installed?
