I got confused with the scope of alert . I wanted to create ospf neighbour down alert .
What should I have to select under scope of alert If I set the scope of alert to "only following set of objects "
You need to choose ‘Routing Neighbors’ as per the instructions in this article - Success Center
I saw the article , my question is about the "scope of alert" . If I don't want all objects ,(eg i need only two nodes ) ,
How can set the condition
Sorry I misunderstood, so in the Scope of the Alert select “Only following set of objects” and then use the rules to set specific hosts.
