I am attempting to add a node running WINOS 2016 and SQL 2017.
I define the node to use WMI/ICMP and enter and test the credentials. Works fine. I then advance to CHOOSE RESOURCES.
On my SQL 2016 server, the APPINSIGHT for SQL monitor came up automatically.
When I add the SQL 2017, APPINSIGHT for SQL does not appear. Nor is it available to be added manually in the following screen.
Any help is appreciated.
