Please share step by step to add jmx service in monitoring.
Hi sandipc! You'll need SAM to be able to do that kind of monitoring, but assuming you have it, the smoothest way to get it going is by using the Component Monitor Wizard. You can find it by going to Settings > All Settings > SAM Settings (under Product Specific Settings) > Component Monitor Wizard > check the box for JMX. Once you've clicked browse in the next window to choose your Java system it'll give you a list of possible JMX monitors to choose from. From there you can create a new template which you can then apply to your device.
