quote:Originally posted by CCrewI think you need to be more specific on what you're trying to achieve. On a HSRP standby group, ie: between two Ciscos, you can point Orion at the VIP that you are using for the standby group, and the ping will be indicative of the VIP but deeper SNMP polls are only going to get you the interface information of the active router in the standby group. That polling is problematic in that if the VIP fails over to it's partner the interfaces will go unavailable.Scenario I use is to SNMP poll the individual routers directly for all their interface information, then add the VIP's as nodes with SNMP turned off just to get the uptime and latency numbers, which also then allows you also to alert on the VIP's. For deeper info on the actual interface statistics I just use the router metrics.Best way to do it I've found, if someone has a better one I'd love to hear it myself!Regards,Roger
quote:Originally posted by Network_GuruWhat Roger Said!
