I'm using the universal poller to query the status of a QLogic SAN switch, which uses a MIB not provided by the NPM (.1.3.6.1.3.94 / FCMGMT-MIB)
I created two seperate pollers (with GET TABLE) as specified in another post:
.1.3.6.1.3.94.1.10.1.17 as SANPortName (aka. "Port1")
.1.3.6.1.3.94.1.10.1.23 as SANPortStatus2 (aka 4 for active, 8 for link down)
I set up the enumerated values for SANPortStatus2 and added column .2 as the label identifier for both pollers. The node details page now shows the port names and text status, but now I would like to add an alert for rows in that poller that are marked "link down"
My Alert is set up to monitor "Custom Node Poller", triggers are:
Poller Name is equal to SANPortStatus2
Status is equal to Link Down
There are currently two ports that are link down, but the alert only triggers once. What bothers me is that when I try to set up a custom SQL query to pull the port name, it didn't work. I found out why later when I just put the variables in instead of the SQL query I was attempting. The variables is showing ALL rows when it triggers the alert. Here's an example with the alert text = ${CustomPollerStatus.RowID} ${CustomPollerStatus.Status}
2/23/2010 10:02 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.1, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.10, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.11, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.12, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.13, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.14, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.15, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.16, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.2, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.3, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.4, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.5, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.6, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.7, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.8, 16.0.0.192.221.13.115.15.0.0.0.0.0.0.0.0.9 Active, Active, Active, Active, Active, Active, Active, Link Down, Active, Link Down, Active, Active, Active, Active, Active, Active
It shows all the rows in the table not just the row(s) that are "link down." Is there any way to alert on a single row in a poller, not the entire poller?
