I used one of the sample scripts from the SDK that was provided. I successfully added the node, I can see it in the database itself and in my listing of nodes in the "All Nodes" tree on my SW Home page. This issue is then I go to Manage Nodes in Admin > Node Mangement > Manage Nodes. Any node I add from perl does not appear, see screen shot:
Note that I did not assign a vendor hence the Vendor showing up as unknown. What property am I missing that would allow me to see a node here similar to one added from the GUI?
My code... Its pretty much just what was in the example aside from username, password, ip addressing stuff I removed.
use SW::InformationService;
use SW::Orion;
use SOAP::Lite;
my $hostname = "xx.xx.xx.xx"; # fill in a hostname
my $username = "username";
my $password = "password";
my $endpoint = "https://$hostname:17778/SolarWinds/InformationService/v3/OrionBasic";
my $swis = SW::InformationService->new();
$swis->outputxml("true");
$swis->proxy($endpoint);
$swis->proxy->ssl_opts(verify_hostname => 0);
$swis->proxy->http_request->authorization_basic($username, $password);
# Example of Create operation: Add a new node.
# Important: This is just an example of how to call Create operation. List of properties
# is not complete and needs to be filled in with valid values.
# See 'Orion SDK.pdf' for more details on how to properly add a node.
print $swis->Create('Orion.Nodes', {
'Caption'=>'TestNodeFromPerl2',
'IPAddress'=>'x.x.x.x',
'IPAddressGUID'=>ip2guid('x.x.x.x')
Edit:
To add a little mode detail I am able to search for the nodes I added as well named "TestNodeFromPerl", was able to find them via a search.
After a little more trial and error and messing with the database I learned a little more about whats going on. What I'm looking for is the set of tables or objects I need that will mimic the process of adding a node similar to the GUI to get the full functionality.
