For an interface which is UNMANAGED, I am getting a Current Percent Utilization of an interface is 66873%(Transmit) & 1273%(Receive).
Can anyone suggest, how can we resolve this?
We do not want the entry to come up at all.
TIA
Hi TIA,
check what bandwidth do you have for the interface. Orion > Node Management > click [+] next to node which contains this interface > check the checkbox next to interface > click 'edit properties' on top bar > check values in In/Out Bandwidth. Most probably the value there is 1000 or so bigger than real interface speed. Set it correctly and save the settings.
