We have an odd issue on some Cisco ACI servers after a firmware upgrade. I am curious to see if anyone else is running into this or has seen this.
The PSUs on 3 of our Cisco ACI servers are now showing critical errors in SolarWinds after a firmware upgrade to fix power supply errors in the firmware. I was told the old firmware was causing the PSU status to bounce red/green on the servers and this firmware was to fix it. But the new firmware now causing the PSUs to read down/critical by SolarWinds., even though it is stable and running on the servers. The CIMC logs are not alerting and everything is within specs. As of right now, the CIMC says everything is ok. But I am hearing that the ACI says the there is an issue.
Our data center network group is opening a Cisco TAC case, but I am checking here to see if anyone has run into this as well.
Cisco ACI:
Firmware Version: 4.0(2f)
Model: UCS C220M4
Bios Version: C220M4.4.0.2a.0.1023180315
SolarWinds:
Orion Platform 2018.2 HF6, WPM 2.2.2, IPAM 4.7.0, SRM 6.7.0, NPM 12.3, DPAIM 11.1.0, VMAN 8.3.0, SAM 6.7.0, NetPath 1.1.3
cobrien
