Hi, well im to use SolarWinds-Orion-v8-SLX. I have few questions:
1) Currenlty im using NPM v7 with database on another server. If i upgrade it to v8, will the same old database results be available with this new version?
2) Also, can i integrate Netflow Analyzer into this new Solarwinds so that from single webpage i can access both?
what should be the upgrade steps? i mean should i simply extract the zip and install it on the server which is live having around 300 nodes (v7).
would be waiting for your response,
Regards,
M Rizwan ul haq
