I am looking for feedback on which route I should take with our Windows 2016 upgrade. We are currently on 2012 R2 and SQL 2012 looking to go to 2016. We have Orion platform 2017.3.5, NPM 12.2, SAM 6.6, WPM 2.2.1, NTA 4.2.3, and a few others. I could go 2 routes and I just need to know if there are any gotchas with either one or if one is easier than the other.
1st Route:
Upgrade Orion and components on old 2012 servers make sure everything is running smooth.
Then install all the latest versions on new 2016 servers and cut over (present the database to the new SQL server, run config wizard, etc.)
2nd Route:
Install same versions of everything on new 2016 servers and cut over (same as above).
Make sure everything is up and running smoothly
Then upgrade everything to the newest versions, NPM 12.3, SAM 6.6.1, WPM 2.2.2, NTA 4.4, etc.
I appreciate any and all feedback, experience, gotchas, and what not to do's. Thanks guys!!
