We are trying to start deploying IOS firmware using the latest version of NCM, however the verify uploaded firmware image command is not working. We are using the default command and consistently receive the error below. I have manually verified the md5 hash on the device and it is correct. Has anyone else ran into this issue and found a solution?
verify /md5 ${NewImageSlot}${NewImageName} ${NewImageHash} ${SuccessRegEx:Verified}
ERROR Process could not continue because execution results do not match expected pattern: Verified
