In my copy of the SolarWinds\Orion SDK\Schema\3.0\Orion.AlertStatus.html document, the notes field is empty for all of the fields. Can anyone either point me to a different doc, or give me the descriptions for the fields/columns of the Orion.AlertStatus table?
(Just trying to make sure I'm handling alerts correctly.)
..and to that end, do I need to be looking into the Orion.AlertTriggered table?
Our main goal is to be pulling alerts for loading into a ticketing system.
Scott Fraley
