Hello All,
I’m having a hard time retrieving IPAM data from the REST API and the Python OrionSDK, specifically I am trying to query the IPAM.Subnet endpoint to create new subnets and make IP reservations but I keep getting empty results list.
I might be querying the wrong endpoint or I have the wrong schema, is there a way I can get help on this issue ?
Version: Orion Platform HF5, IPAM HF1, NCM HF1: 2019.4
example:
sw_results = swis.query(
"SELECT TOP 10 DisplayName, Address, CIDR, Status FROM IPAM.Subnet")
pprint(sw_results)
Output:
{'results': []}
REST call to /SolarWinds/InformationService/v3/Json/Query?query=SELECT+DisplayName+FROM+IPAM.Subnet
return the same results as well:
