Hi All,
I am trying to replicate what can be done in the UI of Manage Subnets & IP Addresses and trying a way to export the structure only using SWQL. Would appreciate some pointers as I am still learning SWQL and the OrionSDK.
Thank you!
Not looked at this from a SWQL point of view. I have some various reports using SQL, and can tell you that the folders are referred to as groups.
Take a look here this describes the IPAM Powershell API. This can also be converted to a regular REST API Query.
https://github.com/solarwinds/OrionSDK/wiki/IPAM-2019.4-and-higher-versions-API
