we are in process to do some wan automation for our remote sites running on two wan links using power shell scripts.
Our developer has created a powershell script using which we can see what is the primary & secondary link on the site & if needed we can flip the lines as well.
The whole purpose of that to make our monitoring team to flip the link based on how the link performance without intervetion of any network guy,
For an instance lets say if a remote site primary link has some issues then then monitoring team will be able to flip the circuit & make it secondary.
I would like to know if there is any way we can use the Solar winds Atlas tool to integrate those created powershell scripts & can flip the link priorities just by doing a simple click on the link ?
