Since I have upgraded to Orion NPM 9.5, i have some troubleswith graphics.
Firstable, I don't know how to add user graphics. My graphics from the previous version have been moved in a directory called Previous Version Maps. Where is the correct location to use ?
Secondly, in the previous version when the status was unknown, Orion used the graphic with extension (for example catalyst1.wmf) ; now it uses this graphic but add a background. Is it possible to remove this background ?
