This Resource will display up to 6 Gauges for Universal Device Pollers. Currently tested on ver 9.5.1.
Known issue:
- Auto-Hide will work if the first gauge's poller is not assigned to node.
Version1.2 (3/4/2010)
**Fixed minor gauge style select issue**
Version 2.1 (3/8/2010)
**Added Linear gauges**
Version 2.4 (3/10/2010)
**Fixed gauge labels not setting correctly when gauge is first added**
**Fixed issue when gauges were first added Gauge Tick Count and Custom Legends were not editable until after the submit button was clicked**
**Added workaround for Warning & Error Thresholds displaying if values were left blank**
Version 3.0 (4/1/2010)
**Fixed Auto-Scale**
**Auto-Hide will work if the first gauge's poller is not assigned to node**
**Added support to display up to 6 gauges**
**Added support to display gauges on up to 3 rows (Radial Gauges Only)**
**Changed Edit page to hide setting for gauges not used**
**Changed Edit page to show/hide Help info**
**changed Edit page to show/hide gauge sample pics**
To install:
Copy CustomOIDEditGaugeDoubleTriple.aspx and CustomOIDEditGaugeDoubleTriple.aspx.cs to InetPub\SolarWinds\Orion\NetPerfMon\Resources folder.
Copy CustomPollerRadialGaugeDoubleTriple.ascx and CustomPollerRadialGaugeDoubleTriple.ascx.cs to InetPub\SolarWinds\Orion\NetPerfMon\Resources\NodeGauges folder.
Copy CustomOIDEditLinearGaugeDoubleTriple.aspx and CustomOIDEditLinearGaugeDoubleTriple.aspx.cs to InetPub\SolarWinds\Orion\NetPerfMon\Resources folder.
Copy CustomPollerLinearGaugeDoubleTriple.ascx and CustomPollerLinearGaugeDoubleTriple.ascx.cs to InetPub\SolarWinds\Orion\NetPerfMon\Resources\NodeGauges folder.
Any questions or comments please post them here.
