Hi All
I've seen some interface count reports on thwack, but I don't believe it's accurate, as they are using joins. When doing this, it excludes nodes with no interfaces.
This is what I have been using (a very simple query) and it gets me the results for nodes with no interface monitoring.
select n.caption, n.IP_Address [IP_Address], n.vendor [Vendor],
(select count(*) from interfaces i where i.nodeid = n.nodeid) [iCount]
from nodes n
where n.vendor like 'Cisco%'
order by [iCount] asc
It can always be expended to show the poller, etc.
I use it to aid in interface clean up - such as all Cisco nodes needs to have at least 1 interface monitored. Any device with more than 50 interfaces needs to be reviewed.
Amit
