Is there a way to get the serial numbers from all members of the 3750 stack in a report? The canned report in NCM only gives the master of the stack's serial number. Or is it possible with NPM somehow?
Thankser
The Universal Device Poller at http://thwack.solarwinds.com/docs/DOC-123781 will allow you to display the relevant detail on the node details page when used with a NPM tabular resource. Alternatively the NCM inventory report at http://thwack.solarwinds.com/docs/DOC-169053 will do your entire estate of 3750 stacks.
Regards,
John
What version of NCM are you using because there is a built in report that shows the serial nos of all stack members. CISCO 3750 Stack - Physical Entity
Pyro
I ran the CISCO 3750 Stack - Physical Entity report and it do not return any serial numbers. I'm a noob so I might be doing something wrong. What could the issue be?
I'm running NCM version 7.1.1
Do you get any details from the switches at all or is the report just blank?
Do you have an inventory job scheduled?
The report was blank. I didn't run inventory on the devices. Applications tech support for me straightened out.
In order for the report to be accurate you must run an inventory, like pyro13g suggested. Im running 7.2.2, so not sure if other versions are different, but once the inventory is complete go to Reports> View reports, then chose Physical Entities> Physical Entities (Serial Number) v2. After running this report it incuded all my information for all stack members of 3750's and 2960x's and VSS switches.
Cisco 3750 Stack - Physical Entity ConfigMgmt Report
