Exchange Server 2007 (multiple roles)
This zip file include 5 templates that cover the 4 primary roles in Exchange 2007 (mailbox, hub, edge and CAS), plus one (full) that include all services for all roles, excluding the Unified Messaging role (which we have not implemented yet. When you run multiple roles on a single server, you can use the 'full' template to create a template fitting for your environment.
The templates include also those services (for example Monitoring) that are set to manual by default and not running, thus will show red.
The template for the CAS role also includes the POP3, IMAP and SMTP Monitor, while the template for the Edge role include the SMTP monitor.
