i am having issues with solarwinds not being able to monitor my lync sever sql with Appinsight for sql. i am getting the following error
Unable to establish SQL connection, check credentials. A connection was successfully established with the server, but then an error occurred during the login process. (provider: SSL Provider, error: 0 - The client and server cannot communicate, because they do not possess a common algorithm.)
Has anyone come across this and do you know what is causing it. I am using the administrator credentials which has full access to the databases.
