I'm using powershell 4 and Orion Platform 2017.3.2.SP2, took some example scripts from others that were reported to be working and cleaned them up for my environment but when I try to run them in my environment they will run for a few seconds/minutes and then I keep getting errors saying that parsing of discovery results failed.
Everything looks good from the powershell side as far as it not kicking back any errors.
here is the script
if (!(Get-PSSnapin | Where-Object { $_.Name -eq "SwisSnapin" })) {
Add-PSSnapin "SwisSnapin"
#define target host and credentials
$hostname = 'localhost'
$user = "admin"
$password = "password"
# create a connection to the SolarWinds API
$swis = connect-swis -host $hostname -username $user -password $password -ignoresslerrors
$CorePluginConfigurationContext = ([xml]"
<CorePluginConfigurationContext xmlns='http://schemas.solarwinds.com/2012/Orion/Core' xmlns:i='http://www.w3.org/2001/XMLSchema-instance'>
<BulkList>
<IpAddress><Address>10.40.40.63</Address></IpAddress>
</BulkList>
<Credentials>
<SharedCredentialInfo>
<CredentialID>57</CredentialID>
<Order>1</Order>
</SharedCredentialInfo>
</Credentials>
<WmiRetriesCount>1</WmiRetriesCount>
<WmiRetryIntervalMiliseconds>1000</WmiRetryIntervalMiliseconds>
</CorePluginConfigurationContext>
").DocumentElement
$CorePluginConfiguration = Invoke-SwisVerb $swis Orion.Discovery CreateCorePluginConfiguration @($CorePluginConfigurationContext)
$InterfacesPluginConfigurationContext = ([xml]"
<InterfacesDiscoveryPluginContext xmlns='http://schemas.solarwinds.com/2008/Interfaces'
xmlns:a='http://schemas.microsoft.com/2003/10/Serialization/Arrays'>
<AutoImportStatus>
<a:string>Up</a:string>
<a:string>Down</a:string>
<a:string>Shutdown</a:string>
</AutoImportStatus>
<AutoImportVirtualTypes>
<a:string>Virtual</a:string>
<a:string>Physical</a:string>
</AutoImportVirtualTypes>
<AutoImportVlanPortTypes>
<a:string>Trunk</a:string>
<a:string>Access</a:string>
<a:string>Unknown</a:string>
</AutoImportVlanPortTypes>
<UseDefaults>true</UseDefaults>
</InterfacesDiscoveryPluginContext>
").DocumentElement
$InterfacesPluginConfiguration = Invoke-SwisVerb $swis Orion.NPM.Interfaces CreateInterfacesPluginConfiguration @($InterfacesPluginConfigurationContext)
$EngineID = 9
$DeleteProfileAfterDiscoveryCompletes = "false"
$StartDiscoveryContext = ([xml]"
<StartDiscoveryContext xmlns='http://schemas.solarwinds.com/2012/Orion/Core' xmlns:i='http://www.w3.org/2001/XMLSchema-instance'>
<Name> Test $([DateTime]::Now)</Name>
<EngineId>$EngineID</EngineId>
<JobTimeoutSeconds>3600</JobTimeoutSeconds>
<SearchTimeoutMiliseconds>2500</SearchTimeoutMiliseconds>
<SnmpTimeoutMiliseconds>2500</SnmpTimeoutMiliseconds>
<SnmpRetries>1</SnmpRetries>
<RepeatIntervalMiliseconds>2500000</RepeatIntervalMiliseconds>
<SnmpPort>161</SnmpPort>
<HopCount>0</HopCount>
<PreferredSnmpVersion>SNMP2c</PreferredSnmpVersion>
<DisableIcmp>false</DisableIcmp>
<AllowDuplicateNodes>false</AllowDuplicateNodes>
<IsAutoImport>false</IsAutoImport>
<IsHidden>false</IsHidden>
<PluginConfigurations>
<PluginConfiguration>
<PluginConfigurationItem>$($CorePluginConfiguration.InnerXml)</PluginConfigurationItem>
<PluginConfigurationItem>$($InterfacesPluginConfiguration.InnerXml)</PluginConfigurationItem>
</PluginConfiguration>
</PluginConfigurations>
</StartDiscoveryContext>
").DocumentElement
$DiscoveryProfileID = (Invoke-SwisVerb $swis Orion.Discovery StartDiscovery @($StartDiscoveryContext)).InnerText
This is what I see in my discoverprofiles table
No entry gets added to the discoverylogs for these
Anyone have any suggestions?
I already tried modeling my discovery after what was in this post and the wiki, i basically get the same results no matter which one I use.
API Network Discovery
OrionSDK/DiscoverSnmpV3Node.ps1 at master · solarwinds/OrionSDK · GitHub
