this is new for me, I've not used Solar Winds or the forum before so apologies if this is the wrong place or something 'obvious' that I've missed.
I'm using Toolset version 10.4.0.57 on an XP PC.
I worked through the user guide chapter two last night and tried individual charts, gauges, etc, they worked OK.
Now I'm trying to use Workspace to set up interface monitoring...
new tab, drag 'interface chart' over, drag a device onto it,
select the device, click 'next'
leave it on all interfaces, click 'go'
tick the WAN interface
click 'bandwidth' (or any other on the bottom left panel)
I'm stuck at this point. The 'create chart item' doesn't light up so I can't click it.
I get the same with other 'interface' gadgets but 'reponse time chart', gauge, etc, seems to work OK.
Any ideas please?
I can see the bandwidth, etc, if I use tools under 'Network Monitoring', ie, bandwidth gauges pointing at the same router.
Regards
Peter
