When I add a new wpm poller, i would like to skip the initial 5 min wait to populate data into Orion. Is there a verb to have the Orion SDK do a "play now" action against a node?
Hello,
I'm not sure I understand what exactly are you trying to do. Do you mean that if you add a new WPM player and assign a transaction it takes 5 minutes to get the first data? Or is it something else? If you can provide step-by-step list what you do it would be helpful.
Sorry for the confusion. I am trying to use the sdk to do what "play now" button does on the WPM transactions.
