I was pretty excited to see the switch port mapper program, however, it doesn't seem to work on the majority of my switches....Run-time error '457':This key is already associated with an element of this collection.RS
I found out why this is happening (as I also have an older version of the Port Mapper software and searched for this error) - Certain switches can return multiple exact MIBs while still continuing through the SNMPwalk - but the array type that SolarWinds used cannot handle multiple like entries in their index; and instead of checking to see if the index already exists, ignoring that entry & continuing it's abending.
Linux SNMP tools can help diagnose the problem if you have access to a linux box with them - there are also freeware tools for Win32 - google is your friend here. This is what I did:
snmpwalk -On -c mycommunityhere -v 2c -Ct -Cc 10.123.456.789 > AllDellSwitchInfo.txt
[[ If you leave off the -Cc switch, the SNMPwalk command will barf on the first duplicate (or non-increasing) MIB... but if you left it in, you can use linux to find the offending lines pretty easily: ]]
awk '{print $1}' < AllDellSwitchInfo.txt | uniq -d
These are the repeated MIBs on my Dell PowerConnect switch:
.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.153.18 = Hex-STRING: 00 16 C7 2C 99 12.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.185.191 = Hex-STRING: 00 16 C7 2C B9 BF
There were 3 instances of each of these MIBs in the full SNMPWalk.
Hope this helps!Roger "Merch" Merchberger
Roger - Is it returning different ports for each mac or the same port multiple times? Do those ports resolve to the same interface or different physical interfaces?
Greg
It's tough for me to tell - I know enough about SNMP & SolarWinds to fix things when they break, but I don't know enough to know MIBs by heart or anything... I widened some of the search parameters, and this is what I found:
root@linux:/var/log# grep -i '0.16.C7' AllDellInfo.txt<br />.1.3.6.1.2.1.4.22.1.2.1.10.102.1.254 = STRING: 0:16:c7:2c:b9:bf<br />.1.3.6.1.2.1.4.22.1.2.1.10.102.7.1 = STRING: 0:16:c7:2c:b9:bf<br />.1.3.6.1.2.1.4.22.1.2.1.10.102.10.1 = STRING: 0:16:c7:2c:b9:bf<br />.1.3.6.1.2.1.4.22.1.2.1.10.102.11.1 = STRING: 0:16:c7:2c:b9:bf<br />.1.3.6.1.2.1.17.2.15.1.8.49 = Hex-STRING: 80 01 00 16 C7 2C 99 00<br />.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.153.18 = Hex-STRING: 00 16 C7 2C 99 12<br />.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.153.18 = Hex-STRING: 00 16 C7 2C 99 12<br />.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.153.18 = Hex-STRING: 00 16 C7 2C 99 12<br />.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.185.191 = Hex-STRING: 00 16 C7 2C B9 BF<br />.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.185.191 = Hex-STRING: 00 16 C7 2C B9 BF<br />.1.3.6.1.2.1.17.4.3.1.1.0.22.199.44.185.191 = Hex-STRING: 00 16 C7 2C B9 BF
To someone who doesn't know much about these things, I'd have to surmise that it's 'secondary data' being relayed in the later repeated MIBs, so I don't think it's an "IP->MAC" or vice-versa issue here. If I can forge a guess of "Most IP address based MIBs will be the last 4 octets thereof" we certainly don't have anything in the 199.44.x.x type address, and you can see earlier that the MAC address is sitting squarely in the 10.x.x.x Class A which is where it should be. ;-)
I did an SNMPwalk of just '.1.3.6.1.2.1.4.22' and it returned all the MAC addresses & IPs on the switch and it didn't return any duplicate data (and did return pretty much exactly what I was looking for... yay!), so with that I also don't think it's a port-reporting problem.
.1.3.6.1.2.1.4.22
I pretty much figured that it's just a bug in Dell's firmware, but when I googled, folks said there were issues with Ciscos & other equipment, too. I realize that there shouldn't be duplicate MIBs... but I learned long ago that shoulds's and is's can vary greatly. ;-)
I can make the whole SNMPwalk file available to you if it will help you. It's about 1Meg uncompressed, but the .gzip is only 82K.
Thanks, and hope this helps!Roger "Merch" Merchberger
Thanks Roger - Can you please walk the following MIB?
1.3.6.1.2.1.17.4.3.1.2.0.22.199.44.153.18
This will be the ports column of the forwarding table. It relates the MAC to the port to send it out on.
