One of my SolarWinds priorities is displaying as much actionable information as possible without burning up half the screen with empty panels. This panel has been through a number of revisions, but is (more or less) useful now. This SWQL Custom Query creates a panel that consolidates:
- Nodes with High Packet Loss
- Nodes with High Response Time
- Nodes with High Average CPU Load
- Volumes with High Percentage Usage
- Nodes with High Memory Utilization
Clicking on the issue opens up a 7 day perfstack analysis. Clicking/Hovering over the node name works as you would expect.
It is also searchable by node name or issue name (packet loss, response time, high cpu, cpu load, disk space, memory used).
I hope people find this useful. It saves a ton of space on our NOC display.
-- Node Issues Panel - SWQL Custom Query Resource
-- 3-Jan-2020 Christopher Camacho
-- Conserve screen space by consolidating 5 panels into 1
-- * Nodes with High Packet Loss
-- * Nodes with High Response Time
-- * Nodes with High Average CPU Load
-- * Volumes with High Percentage Usage
-- * Nodes with High Memory Utilization
-- Click/Hover on Node Name for Node Details
-- Click on Issue to open PerfStack Analysis (7 Days)
-- Search by Node Name or Issue (Packet Loss, Response Time, High CPU, CPU Load, Disk Space, Memory Used)
-- DISK SPACE BLOCK
SELECT N0.Caption AS [Node],
N0.DetailsUrl AS [_LinkFor_Node],
'/Orion/images/StatusIcons/Small-'+N0.StatusIcon AS [_IconFor_Node],
' '+toString(Round(ov.VolumePercentUsed,0))+'% '+ov.Caption AS [Issue],
'/ui/perfstack/?presetTime=last7Days&charts=0_Orion.Volumes_'
+toString(ov.VolumeID)+'-Orion.VolumeUsageHistory.PercentDiskUsed;'
AS [_LinkFor_Issue],
CASE
WHEN (ov.VolumePercentUsed>=ov.ForecastCapacity.CriticalThreshold)
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_FileServer-Critical.png'
WHEN (ov.VolumePercentUsed>=ov.ForecastCapacity.WarningThreshold)
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_FileServer-Warning.png'
ELSE '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_FileServer-Up.png'
END AS [_IconFor_Issue]
FROM Orion.Volumes ov
LEFT JOIN Orion.Nodes AS N0 ON N0.NodeID=ov.NodeID
WHERE N0.UnManaged=FALSE AND
-- Uncomment the next line when enabling search
-- AND ('Disk Space' LIKE '%${SEARCH_STRING}%' OR ov.Caption LIKE '%${SEARCH_STRING}%' OR N0.Caption LIKE '%${SEARCH_STRING}%')
-- BEGIN PACKET LOSS BLOCK
UNION
' '+toString(N0.PercentLoss)+'% Packet Loss' AS [Issue],
'/ui/perfstack/?context=0_Orion.Nodes_'+toString(N0.NodeID)
+'&withRelationships=true&presetTime=last7Days&charts=0_Orion.Nodes_'
+toString(N0.NodeID)+'-Orion.ResponseTime.PercentLoss;'
CASE
WHEN (N0.PercentLoss>=N0.PercentLossThreshold.Level2Value)
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Generic-Critical.png'
WHEN (N0.PercentLoss>=N0.PercentLossThreshold.Level1Value)
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Generic-Warning.png'
ELSE '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Generic-Up.png'
FROM Orion.Nodes N0
WHERE N0.UnManaged=FALSE AND N0.External=FALSE AND
-- AND ('Packet Loss' LIKE '%${SEARCH_STRING}%' OR N0.Caption LIKE '%${SEARCH_STRING}%')
-- BEGIN CPU LOAD BLOCK
UNION
' '+toString(N0.CPUload)+'% CPU Load' AS [Issue],
+toString(N0.NodeID)+'-Orion.CPULoad.AvgLoad;'
CASE
WHEN (N0.CPUload>=N0.CpuLoadThreshold.Level2Value)
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_CPU-Critical.png'
WHEN (N0.CPUload>=N0.CpuLoadThreshold.Level1Value)
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_CPU-Warning.png'
ELSE '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_CPU-Up.png'
FROM Orion.Nodes N0
AND (N0.CPUload>=N0.CpuLoadThreshold.Level1Value)
-- AND ('CPU Load' LIKE '%${SEARCH_STRING}%' OR 'High CPU' LIKE '%${SEARCH_STRING}%' OR N0.Caption LIKE '%${SEARCH_STRING}%')
-- BEGIN RESPONSE TIME BLOCK
UNION
' '+toString(N0.ResponseTime)+'ms Response Time' AS [Issue],
+toString(N0.NodeID)+'-Orion.ResponseTime.AvgResponseTime;'
CASE
WHEN N0.ResponseTime>=N0.ResponseTimeThreshold.Level2Value
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Switch-Critical.png'
WHEN N0.ResponseTime>=N0.ResponseTimeThreshold.Level1Value
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Switch-Warning.png'
ELSE '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Switch-Up.png'
FROM Orion.Nodes N0
(N0.ResponseTime>=N0.ResponseTimeThreshold.Level1Value)
-- AND ('Response Time' LIKE '%${SEARCH_STRING}%' OR N0.Caption LIKE '%${SEARCH_STRING}%')
--BEGIN MEMORY USED BLOCK
UNION
'/Orion/images/StatusIcons/Small-'+StatusIcon AS [_IconFor_Node],
' '+toString(PercentMemoryUsed)+'% Memory Used' AS [Issue],
+toString(N0.NodeID)+'-Orion.CPULoad.AvgPercentMemoryUsed;'
CASE
WHEN N0.PercentMemoryUsed>=N0.PercentMemoryUsedThreshold.Level2Value
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Memory-Critical.png'
WHEN N0.PercentMemoryUsed>=N0.PercentMemoryUsedThreshold.Level1Value
THEN '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Memory-Warning.png'
ELSE '/Orion/HardwareHealth/Images/StatusIcons/Object-Sensor_Memory-Up.png'
FROM Orion.Nodes N0
(N0.PercentMemoryUsed>=N0.PercentMemoryUsedThreshold.Level1Value)
-- AND ('Memory Used' LIKE '%${SEARCH_STRING}%' OR N0.Caption LIKE '%${SEARCH_STRING}%')
-- END OF BLOCKS - DO NOT DELETE/COMMENT 'ORDER BY' LINE BELOW
ORDER BY [Node], [Issue]
