Hi, I would like to ask if all traffic flows on a interface can be exported (i.e. xls, csv, raw) or viewed from GUI?
I believe currently now we can only view a conversation flow from 1 IP address to another.
I'm not sure I understand your question exactly. Using our online demo site as an example, you can see the top 5 endpoints. Of course, you can change this to any number of endpoints you would like to see. Is this the data you are looking for?
http://oriondemo.solarwinds.com/Orion/TrafficAnalysis/NetflowInterfaceDetails.aspx?NetObject=NI:2220
Or are you looking for something more like the conversation traffic history on the conversation details page?
http://oriondemo.solarwinds.com/Orion/TrafficAnalysis/NetflowConversationDetails.aspx?NetObject=NC:10199120160-208065153238;I:2220;T:Last%201%20Hours
If the second one, then there isn't a great way to do it in the UI. It is possible to extract this directly from the database, but it will be quite a lot of data. Can you tell me more about what you are trying to do exactly?
Mav
I am trying to export the flow data (In your second screen shot Conversation Flows), but for a particular interface of an equipment. Preferably xls or csv raw data.
Although we can do it by clicking multiple times from (First screenshot - Top xxx Endpoint), but i dont think that is an efficient way to do it, as i am exporting more than just the top 5 flows.
Do you see what you need via the Endpoint View, after searching for your device's IP address>
The endpoint view will only show 1 conversation's data flows.
However i am trying to export the flow data of the interface which consist of different IP addresses.
BUMP!
We would like to have the ability to export the data below to CSV, Excel and PDF:For now, the only workaround we are using is opening this page on chrome and saving the page via pdf.unfortunately, the whole page is being saved and not all the pages are captured depending on the size of the resources.
Thanks!
