I am trying to write a custom Application Monitor to monitor the status of our Outlook sessions. All our users use Terminal Servers to connect to our VM environment. Thus at times we may have 25 instances of Outlook running. I used the Find Processes, Services and Performance Counters wizard and searched Processes-WMI. I located all the Outlook Performance Counters and applied them to a new template. I do nto know what I should use for Instance settings. SHould I use the Convert Vlaue an dif so, what? When I apply the template to the server all I get is all red an ddown for everything. Anyone have any experience with Outlook monitoring?
Thank you
Greg
