In Orion NPM, you can add the Percent Utilization of All Interfaces resource and then use the custom Filter Nodes (SQL) to only show the interfaces you want.
The Top XX Netflow Sources by % Utilization doesn't have that option under edit. Is there some other way of doing this?
I'm looking to just display say the Top XX Netflow sources by % util of just my MPLS interfaces on different routers. I tried the build view resource, but it only lets you pick one node.
