Hi, am new to Netflow.
Don't have Orion. Just wanted to use the simple features of Netflow - scanning the capture file.
Downloaded Netflow last week -12/5. Is it necessary for the IOS to be at 12(4) on routers?
My IOS on routers is 12.3(8r) released software.
Am using snmp V2. I have XP Svc Pk 4 on PC.
The ports show traffic in and out of the router incrementing; I see the netflow statements in the router config, but there are no check marks on " Sending Netflo" .
Does not send to the capture file.
Appreciate any insight. It will be a while for us to get 12.4 IOS installed.
Perhaps trying to use Netflo is not what I should do now.
Kevin
