Hi, Can IPMonitor use Netflow?
Is there a way to have IPMonitor accept/report on netflow data?
No ipMonitor cannot process NetFlow data, you should have a look at Orion NetFlow Traffic Analyzer for that.
www.solarwinds.com/.../index.aspx
may sounds like a daft question, as the answer is most probably in the title, but can this be integrated with IPMonitor?
No, NetFlow data is only available from within Orion.
