What is the maximum throughput anyone has put into NTA?
Anyone scaled this up to over 75,000 flows/second?
Suggested architecture, storage?
50K per poller and 300K max per primary instance of orion is what is documented. I have a client that is seeing over 75k flows per second that they have distributed across multiple pollers. They are running the min spec system suggested in NTA DB server documentation, which I would not suggest as an ideal deployment, but it is able to handle the job. The problem they see, which they are ok with, is the resources render a little on the slower side in the web console than they would like.
Awesome! I have 4 additional pollers, so that should be able to cope with 200K flows/second.
[I seem to often bleed on the size edge of some of the Solarwinds products so it's nice to have someone running a larger install of any product.]
