If I create an alert that "should not" throw an action against a node and I run a test against that node I should yield no action correct?
This is my alert: Server Node (Non SQL)
Trigger action:
Percent Memory Used is > or = to 80%
DB Admin is equal to No
SYS Admin is equal to Yes
Node in question is setup with these custom properties:
DB Admin = False
SYS Admin = True
Action is to email.
So the way this is setup is all of our NON SQL servers are (DB Admin = False, SYS Admin = True)
So the NON SQL servers should fire off this alert.
Our SQL servers are (DB Admin = True, SYS Admin = True). We have a seperate alert setup to catch this "True/True" custom property..
When I run my NON SQL alert against a SQL server I get an email. Is this by design? I figured I would just see a test log that says something to the effect of "NO ACTION"
