I want to use IPmoitor to check the status of device by telneting a server and capture the log from server by command and from that log it will check the status of devices which are listed in log.
brief:
step -1 : telnet xxx.xxx.xxx.xxx login:< > password <>
step-2 : fire a command on telnet and take log of the result.The result is having 50 lines output which are different devices and i have to monitor them.
step-3 : the device status are in above log
step-4 : update the status of device by checking the log.
Is it possible
