Hi, I've done a ton of tryes with web report builder and netflow ingress an egress by device or by node doesn't match the real traffic if I check manually from the Netflow tab, select the object and limit the date.
Ive used a lot of combinations, custom table:
by a node group
Node Name -> netflow history -> ip group -> total bytes or bytes ingress and bytes egress
Node Name -> netflow by ip history -> ip group -> total bytes or bytes ingress and bytes egress
by interface group
Full name -> ip address group name -> Total Bytes
Bytes are measured in bytes (1000b) and the result is the sum of the time period.
Are these reports obsolete? the netflow one's on the report builder tool are not working any more. I am not an sql expert.
Ive used a lot of combinations, Node Name -> netflow historical -> ip group -> total bytes or bytes ingress and bytes egress
