Has anyone gotten sflow on their 9K's to work with NTA? Solarwinds support says the 9k is sending sflow in layer2 format and NTA needs layer3. I don't see this as option to set. From support:
"Your device is only sending Layer 2 flows which is the Counter Samples"
Using the exact same config but pointing the collector to Plixar Scrutinizer, it pulls and displays sflow data.
Any help would be appreciated.
Dave
